Mirage III et dérivés (1/200)
Jeffb
Re: Mirage III et dérivés (1/200)
Message par Jeffb »
cafecomics a écrit : mar. janv. 15, 2019 11:11 pm If you print 1:200 models at 66.67 % you get 1:300.
Cheers 👍🏻👍🏻
Jeffb
Message par Jeffb »
Is there a link for instructions on how to build the Mirage III and Mirage 2000?
Many thanks
Jeff
A remercié : 1360 fois
See this thread for the Mirage III/5.
I don't think I've made a build thread for Bruno's Mirage 2000.
Jeffb
Message par Jeffb »
Appreciate all the help, just need a Rafale template now and happy days.
Jeff
Bruno has a series of Rafale in 1:100. PM him at Papermodelers.com (1 €/$ each). He's also released a free 2-seater in a special scheme.
Jeffb
Message par Jeffb »
Could I recolour it in inkscape? And what percentage is it to rescale to 1/300.
I really appreciate the help.
Jeff
To go from 1:100 to 1:300 the factor is 33.3333% (100/300*100)
To go from 1:200 to 1:300 the factor is 66.6666% (200/300*100)
(Inkscape allows that many numbers after the separator when resizing).
Bruno's models are vector-based. So you can edit them with Inkscape.
Jeffb
Message par Jeffb »
Any plans to bring out the various versions of the Atlas/ Denel Cheetah?
Love the planes by way, great work.
Jeff
I guess I could do the Cheetah E and D pretty quickly as most if not all parts already exist. The only doubt would be the modified ventral keel with built-in chaff/flares dispensers, unless I could revise the one I made for the Pantera CN.
The Cheetah C would still need some new parts. If the extended front fuselage and the single-frame windshield (D included) were done years ago, I need to make at the very least a new nose cone and a new IFR probe. The fin for all of those already exist too.
Pics of the Pantera CN:
Jeffb
Message par Jeffb »
Excellent work, thanks for the reply. I appreciate it.
Un Mirage IIIC et un Mirage IIIB sud-africains dans le classique camo semi-désertique.
pdfc-MirageIIICZ-1_200-mod3h-2014-za-part2-camo.pdf
1 x Mirage IIICZ + 1 x Mirage IIIBZ, sqn 2 SAAF, camo
(516.51 Kio) Téléchargé 224 fois
Sinon, j'ai un ersatz de Cheetah E, un assemblage de pièces de Mirage IIIE et de Kfir C7 avec une nouvelle quille, une dérive révisée et quelques pièces récupérées sur le Mirage 5 COAM et/ou le Pantera 50CN. Le Cheetah D échangerait juste le fuselage avant, le nez et la verrière. Profils provisoires des Cheetah E et D:
Edit; Ersatz/approximation parce que je n'ai pas beaucoup de doc. Sinon, je viens de finir une déco.
Modifié en dernier par cafecomics le lun. févr. 11, 2019 5:09 pm, modifié 2 fois.
J'ai révisé les Mirage IIICZ/BZ sud africains en livrée métal. Aucun changement à part la mise en page et la couleur des verrières et tuyères.
pdfc-MirageIIICZ-1_200-mod3h-2014-za-part1-metal.pdf
1 x Mirage IIICZ + 1 x Mirage IIIBZ, sqn 2 SAAF, métal naturel
(675.73 Kio) Téléchargé 257 fois
Jeffb
Message par Jeffb »
Great work, appreciate it.
Cheetah D.
Avec l'Atar 9C d'origine.
Ou remotorisé plus tard avec l'Atar 9K50.
Il y a quand même pleins d'inconnues. Parmi elles, quelle quille utiliser ? J'avais fait la V5 pour le Cheetah C et la V4 pour le Pantera chilien. J'ai aussi bien envie de refaire les accessoires du nez. Et peut-être flouter un peu les bords du gris foncé même si ça augmente toujours le poids du pdf final.
La même chose avec un flou de 6% (en général) sur les bords du gris foncé.
Si c'est bon, il y aura juste à copier-coller le calque "couleurs" vers le fichier du 849 sud-africain.
